I downloaded the latest BIOS (AY0050.bio) to address the SA-00086 vulnerability.
When I run the SA-00086 Detection Tool, the error message I get is that ICLS is obsolete. Minimum required version is 1.47.715.0
How would I get icls client version 1.47.715.0 ?
Please see attachment for full message from SA-00086 Detection tool.
Nelson
Have you installed the latest version of the Intel TXE Driver package (v3.0.0.1115)? If you haven't, you can download it here: https://downloadcenter.intel.com/download/26435/NUCs-Intel-Trusted-Execution-Engine-Intel-TXE-Driver... Download Intel® Trusted Execution Engine (Intel® TXE) Driver for Intel® NUC Kit NUC6CAYS, NUC6CAYH.
Hope this helps,
Hi Scott,
Thank you for the response.
I had installed the NUC with TXE Driver package (v3.0.0.1115) prior to applying the Security update. I re-installed the TXE driver package (v3.0.0.1115) and the version of icls client is 1.42.682.1
What are the next steps here ?
-Nelson
I presume it didn't work? This is obviously latest version available for NUC6CAYS. I am unsure what else to suggest. Perhaps you should look a the Intel Software Guard Extensions SDK for latest version?
Grasping at straws...
