Intel® NUCs
12107 Discussions
How to install graphics driver for NUC i5 8th gen IRIS PLUS graphics 655 ??
psund3
While installing graphics driver we are getting following error (attached) we are using core i5 8th gen in this OEM natives IRIS PLUS graphics 655 has to be supported but in my case i never seen graphics driver is enabled so please can you help me out troubleshoot this ????
LeonWaksman
  1. Your Windows version is a previously released 1607 Anniversary Update. I suggest that you update is to the latest version 1806 October 2018 Update. Check the pending updates in Windows settings (while connected to Internet).
  2. Download and manually install Graphic Driver: https://downloadcenter.intel.com/download/28437/Intel-HD-Graphics-Driver-for-Windows-10-for-Intel-NU...
  3. I would suggest to download and update all the other drivers and bios: https://downloadcenter.intel.com/product/126148/Intel-NUC-Kit-NUC8i5BEH
  4. You may download and install Intel Driver & Support Assistant and update your computer with this tool: https://www.intel.com/content/www/us/en/support/detect.html
Hope this helps
Leon
PKRIS10
I also have the same problem using driver and support assistant. Getting an error massage that the driver is not supported by this unit.
INTEL® NUC KIT NUC8I5BEH
Intel® Iris® Plus Graphics 655
Installed windows version 1806
LeonWaksman
Did you try manual installation with the link provided in my previous post?
Leon
PKRIS10
I solved this by purchasing software Driver easy😁 But i do think that the drivers provided by Intel driver support assistant should really work without any error massages, They are after all manufacture of the Intel NUC.
LeonWaksman
What you mean by saying "I solved this by purchasing software Driver easy😁" Where did you purchase driver? The Intel drivers are free for download from the link I've provided above. The Intel DSA have some time problems with installation, therefore Intel provided site where you can download any driver. No need to purchase driver.
Leon
PKRIS10
https://www.drivereasy.com/
Its the same as DSA only difference is that it works without doing manual installation
SChau10
New Contributor II
You can also use the following manual driver update sequence:
  1. Un-install existing legacy Intel Graphics driver. Restart system as requested.
  2. Temporarily re-configure display driver back to "Microsoft Basic Display Adapter". Restart as needed.
  3. Launch the exe from the Intel DCH Graphics driver package (6444 or 6471). Restart as requested.
Basically, I discovered that:
  • Legacy Intel Graphics driver --> DCH Intel Graphics driver
doesn't always work (the error reported by multiple people appears), but
  • Legacy Intel Graphics driver --> Microsoft Basic Display Adapter --> DCH Intel Graphics driver
appears to work much more consistently.
I explained in another thread that this has something to do with the DCH Intel Graphics driver having 2-part ID which cannot install over an existing legacy Intel Graphics driver with 4-part ID. The error message is Windows saying you can't replace a 4-part ID driver with a 2-part ID driver by using a driver installer. This is intended functionality of Windows (i.e. by design) and not a bug. The workaround is to get the 4-part ID driver completely uninstalled from the system first, and go through the inbox Microsoft display driver, then the installation of the 2-part DCH driver should proceed successfully.
