Hi, I have been using my Sony XBR 49X800E 4K TV for two years with various computers connecting to it via various HDMI ports. Never has any issue. However, when I connected my NUC7i3BNK to it, the TV shows no signals in other HDMI ports except for the HDMI3 ARC port. How come? How do I make my NUC to use other HDMI ports on the TV?
https://www.sony.com/electronics/televisions/xbr-x800e-series/specifications
(It shouldn't make a difference, but...) Have you tried disabling CEC support in the NUC's BIOS?
(It shouldn't make a difference, but...) Have you tried disabling ARC support in your TV?
Yet another response from Mr. Grasping at Straws,
I have already disabled CES support in the BIOS before posting.
I need ARC support in my TV as I usually connect it to a soundbar and a desktop workstation.
Anybody knows how to fix this issue?
IPC00, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the problem between the TV and the HDMI port of the Intel® NUC still persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
Hello IPC00: Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
