Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to modify BIOS using Integrator tool kit?
Need to update BIOS (Enable the NUC to re-start on its own after power-off rather staying in the power-off mode). How to go about and do this using Integrator tool kit?
Tags (1)
Highlighted
Re: How to modify BIOS using Integrator tool kit?
Are you asking this because it is not working when you make this change in BIOS Setup (Visual BIOS)?
Highlighted
Community Manager
Hello, NUCian:
Were you able to modify the BIOS?
Amy.
