Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11994 Discussions
How to replace a failing fan in NUC6i3SYH?
MHamb2
I have the Skylake NUC and the fan is making a grinding sound. Does anyone know the fan model and how to replace it?
n_scott_pearson
Super User Retired Employee
The blower is a stock part from a number of manufacturers (Delta, Sunon, etc.) and is available from a number of online vendors. A post the other day indicated that you could even purchase them through Amazon.
N​ow, before you do, let's look at repair. Sometimes, you can pry up the cowling around the edges of the opening and stop the rubbing causing the noise. Check this before removing the blower.
Hope this helps,
...S​
MHamb2
Thanks, I found where to order the part and I'll give it a go once it arrives.
