My device is NUC8I5BEH,I tried to stop charging with thunderbolt port when the NUC is off,but I don't know how to make it.Because I'm using an EGPU device,when I power-off the NUC,EGPU's PSU fans still work,because the thunderbolt type was still charging.
I don't have NUC8i5BEH to verify this, however you may try this: In Bios Advanced > Devices > USB, set Portable Device Charging Mode to OFF.
Leon
Thankyou for answering my question,I'v tride your advice ,but didn't work it only affect front yellow type-A port
I knew what's the problem ,I set as you said,it doesn't work ,even the front yellow type-A port still provide charging when NUC is off,how can I fix it?
I'm not sure if this will work, however try it:
In Bios Advanced > Power > Secondary Power Settings enable Deep S4/S5. This will enable deep sleep and will affect also wake up capabilities.
Leon
OK,I will try.
I have tried,it worked ,but just yellow type-A front port,thunderbolt port still provide power in deep s4/s5 states mode
Hello 勇焦000,
This is expected by design. USB power will be provided by the USB port even if the unit is powered off. In BIOS as LEON indicated, you can enable or disable Portable Device Charging Mode, but it will cause the unit to either provide extra power during S4/S5 sleep states or not. I will share your feedback with the appropriate team for future consideration.
Adrian M.
Hello 勇焦000,
We were further investigating this case, we haven't been able to reproduce this behavior, would you mind to check with your device vendor, whether there is any firmware fix (update), like the one on the link below?
https://www.gigabyte.com/us/Graphics-Card/GV-N1080IXEB-8GD/support#support-dl-firmware
Please provide the model of your eGPU, the example above is for Gigabyte and their Gaming Box had this issue which got fixed with the new firmware release.
Also, please install the latest Thunderbolt™ 3 Legacy Driver for Windows® 10 for Intel® NUC.
Note:
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
Adrian M.
Hello 勇焦000,
Thank you for your response.
Please run the following tool and attach the report generated.
1. Intel® System Support Utility (Intel® SSU)
Adrian M.
Hello 勇焦000,
Let me know if you need more assistance.
Adrian M.
Hello 勇焦000,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
