Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to use one power cable for NUC5I7RYH and a monitor (AC 100~240V 1.0A)?
How can I do if I use only one cable to provide power both NUC5I7RYH and a monitor (AC 100~240V 1.0A) ? So that they can work as one unit.
Highlighted
Hello, Wenjie
Could you please provide us with more information about your integration?
Please take into consideration the Intel® NUC5I7RYH has its factory designed PSU / AC-DC ADAPTER and the Monitor on the other hand has its own manufacturer's. Thus, Integrating a different PSU may not be supported depending on the different power consumption required by Intel® NUC5I7RYH and monitor respectively.
Additionally, the input voltage and amperage could be the same but the specific output of the Power Supply PSU / AC-DC ADAPTER may or may not be compatible with both devices.
Caesar B.
