Intel® NUCs
11792 Discussions
How to use the internal USB3.0 interface
ZGGo
Hi
My NUC's model is NUC8i7hvk.I know that there are two usb3.0 ports that are built in. I am looking for a USB adapter cable of this interface shape online,but failed.
Can you tell me how can I get this kind of usb cable . 20-pin to usb A female .
archon
​I remembered the definition of this adapter could be found in the technical reference white paper provided by intel, you can find out the name and usage of each pin of all these three sockets.
In that document it says the connector is Molex part number 5041871874, the paired header of this socket is Molex part number 504186: https://www.molex.com/molex/products/datasheet.jsp?part=active/5041861600_CRIMP_HOUSINGS.xml
ZGGo
This message is very useful,thank you!
n_scott_pearson
Super User Retired Employee
Depending upon where you are in the world, you can purchase a validated cable assemblies from MicroSATACables.
Here is a link to the page for the USB 3.0 cable assembly: https://www.microsatacables.com/intel-nuc-nuc6i7kyk-skull-canyon-internal-usb-3-0-header-cable. Note that, while this page says that the cable assembly is for the NUC6i7KYK, I have been told that it also works with the NUC8i7HVK.
MicroSATACables also has a cable assembly for the IO Header as well. It is available here: https://www.microsatacables.com/intel-nuc-nuc6i7kyk-skull-canyon-internal-common-io-header-df1-25mm-....
Hope this helps,
ZGGo
Thanks for the reply, I bought this and tested it.
But the effect is not very good, through this cable, most usb devices such as mouse and keyboard U disk mobile hard disk can be used normally, but after my device passes this connection, the system does not respond at all, there is no prompt to view the device manager.My device is a camera, other usb3.0 interfaces can work normally, but these two are not working.
David_V_Intel
Hello ZGGo, I am following up with your case and see that we have not heard back from you. Were you able to check the information provided by N. Scott Pearson? If you need more assistance do not hesitate to reply. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
ZGGo
Thank you for your reminder
I have tried the  N. Scott Pearson method,but failed.
I don't know what caused it,is the cable or the Internal interface.I tend to prefer the former,Because this cable looks like a test piece rather than a product.
David_V_Intel
Hello ZGGo, Thank you for your response. The information provided by Scott was correct, in fact we do not support this kind of integration you are trying, since you have the type of cable that is needed or at least the interface needed you will need to look for a cable to integrate it on a third-party site, we do not have cables like that to integrate. Other community members can assist you as well if they have successfully integrate a connection like this. Also, for your reference, you can check information here which could have a kind of integration you are trying: https://www.gorite.com/ * Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there. * Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
