Intel® NUCs
Assistance in Intel® NUC products
13309 Discussions
Hy there, i'm planning tu buy a NUC 9 Pro Kit NUC9vXQNX with Xeon E-2286M and i wonder, ist it possible to use XTU with this CPU. Can i lock CPU Clock on Turbomode on all cores? Can i use Undervolt to safe Energy and for less thermal conflicts?
MBril
AlHill
The Xeon E-2286M is not on the list of supported processors for XTU:
https://downloadcenter.intel.com/download/29183/Intel-Extreme-Tuning-Utility-Intel-XTU
Doc
MBril
Thank you for shared Link an Answer, but i've obtained many Intel Processors bevor, the 6700HQ for Example and it is also not listed by XTU Compatibility but i know 6700HQ was supported when i used it, so Maybe the List is nor complete?!
AlHill
Maybe, but the list currently says only X and K processors are supported, and that is as of 4/30/2020.
Doc
MBril
I think the support means the overcklock function because ihere are so many cpu not on support list wehich i've used bevor with xtu, for undervolt.
thank you :)
MRoss5200
Valued Contributor I
XTU will run on the Xeon QNX system but you may not be able to overclock or undervolt due to it not having an unlocked CPU.
