Community
cancel
Showing results for
Search instead for
Did you mean:
BBear
HyperX Impact HX424S14IB2K2/16 on NUC7i5BNH
I have a NUC7i5BNH on my way ffrom Amazon.
May I know if the 8Gx 2 HyperX Impact HX424S14IB2K2/16 will work?
I prefer DDR2400 for future upgrade. DDR2133 is not readily available in HK anyway.
Thx.
Community Manager
Hello bigbear,
Thank you for joining the Intel Community Support.
I would like to share with you the system memory for Intel® NUC Kits NUC7i[x]BN. It is worth mentioning that 2400 MHz memory modules will work on these Intel NUCs, so you can use it for future upgrade, too.
https://www.intel.com/content/www/us/en/support/articles/000023165/mini-pcs/intel-nuc-kits.html
Additionaly, you can find compatible memory modules on the link below to make sure that you will get the most out of the unit you will be receiving soon.
http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...
I hope you find this information helpful.
Wanner G.
BBear
Based on the below description from 1st link, I think all RAM are suitable DDR4 SO-DIMMS are suitable ?
  • Supports two 1.2V DDR4 SO-DIMMs
  • 1866 MHz and 2133 MHz
  • Unbuffered, non-ECC
  • Single-sided or double-sided
  • Minimum recommended memory: 2 GB
BBear
May I know if it matters if I use single or dual rank sodimm?
Thx.
n_scott_pearson
Super User Retired Employee
Memory is required to be 1Rx8.
LeonWaksman
BBear
I can see Crucial has both single & dual rank while HyperX does not.
As I see many youtubers uses the HyperX, I will go with it (DDR4 2400).
