Intel® NUCs
12322 Discussions
HyperX Memory Module compitable for NUC8i3BEH/NUC8i5BEK??
elgiorgio
Can someone please tell me if they HyperX Memory Module HX426S15IB2/8 is compitable with the above stated NUC?
HyperX 2666mhz, 8GB DDR4 SODIMM, CL15.
Thank you
AlHill
no, your memory is 2666mhz, while the nuc supports up to 2400mhz
Look at this for compatible/tested memory:
https://compatibleproducts.intel.com/ProductDetails?EPMID=126150
Doc
elgiorgio
Thank you for your answer.
I have already this memory module.
But, it dont will default to 2400mhz????
LeonWaksman
2666 MHz memory should work OK on 2400 MHz system. So, you should be able to use it without problem. The opposite way may not work (i.e. 2400MHz   memory on 2666MHz bus).
So, your NUC will not use the full capability of your SODIMM, but will work.
Leon
