Intel® NUCs
Assistance in Intel® NUC products
13292 Discussions
I can't install Intel DSA
GBlij
AlHill
What is the model number of your NUC?
Have you blocked any ports on your firewall? Are you using the windows firewall?
What anti-virus are you using?
Doc
GBlij
It's not a real huc but a Laptop HP elitebook folio 9470m . I have nothing blocked on the firewall. I use Windows firewall and Windows defender
AlHill
IDSA accesses localhost on posts 28385-28389. It also connects to www.intel.com, downloadcenter.intel.com, and downloadmirror.intel.com, all on port 443 (HTTPS).
What version of Windows 10? 1903? 1909?
WHat is your processor model numbrer?
Doc
GBlij
My Windows version 1909 Processor Intel(R) Core(TM) i7-3667U CPU @ 2.00GHz
AlHill
Download, run, and attach (using the paperclip) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Doc
GBlij
This is the report
AdrianM_Intel
Hello GBlij,
  • Can you please let us know what is the installation error you get? (you can attach a screenshot to the thread).
  • Which browser did you use to download the Intel® Driver & Support Assistant? (Intel® DSA) (Google Chrome, Mozilla, Edge, Internet Explorer)
You can try the following:
Adrian M.
A Contingent Worker at Intel
AdrianM_Intel
Hello GBlij,
Were you able to check the previous post?
Let me know if you need more assistance.
Adrian M.
AdrianM_Intel
Hello GBlij,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Adrian M.
GBlij
Hello, I still cannot install DSA Beantwoord / doorgestuurd door: G.K. Blijleven.
AdrianM_Intel
Hello GBlij,
Thank you for the update.
The Intel® Driver & Support Assistant (Intel® DSA) works fine on Intel products, I can see you have an HP EliteBook Folio 9470m in this case we recommend you to use the scanning tools provided by the system manufacturer because it will use the customized drivers for your computer if an update is needed.
Adrian M.
GBlij
Hello, Thanks fort he answer. Beantwoord / doorgestuurd door: G.K. Blijleven.
