Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
I can't play any .cue files (wav, wav DTS, dca or flac)
with Intels graphics/sound (HDMI) driver.
If I use a generic Microsoft driver I can!
Setup:
NUC Kit D54250WYJ (CPU i3 - 8 GB ram - windows 7 sp1) > HDMI >Amplifier: Dennon AVR-1911 > HDMI > LG55LA660V
Highlighted
Re: I can't play any .cue files (wav, wav DTS, dca or flac)
Thanks for joining the NUC community.
This problem does not appear to be an issue with the NUC, please try updating NUC BIOS from the link below:
File name: http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/24326/eng/WYLP... WYLPT10H.86A.0030.EB.EXE
Are you able to play those files without AVR?
Please check the list tested peripherals here:
http://www.intel.com/support/motherboards/desktop/sb/CS-034605.htm Intel® NUC Boards and Kits — Tested peripherals
http://www.intel.com/support/motherboards/desktop/sb/CS-034601.htm Intel® NUC Boards and Kits — Customer-reported peripherals
Allan.
Highlighted
If I make a clean install of windows 7 - fully updated via microsoft update - without Intel's Graphics / HDMI audio drivers - and just use Microsofts generic drivers I can play the files!
By using the generic drives, I can't play HD formats like DTS-HD.
By the way it would not make much sense to play the files without the AVR ;-)
I have downloaded and installed the latest BIOS: from the web site (date 09-19-2014) I think that is the one you refer to?
Units for sound and video:
Intel(R) Corporation
09-09-2014
Version: 6.16.0.3154
Gfx:
Intel Corporation
30-09-2014 (09-30-2014)
version: 10.18.10.3958
