Community
cancel
Showing results for
Search instead for
Did you mean:
Agustav
I can't update NUC7i7BN with Intel® Driver and Support Assistant
Currently i have 5 software updates available, but if i install them they won't disappear of that list (of course i rebooted the box)
Can someone help me how to update please?
n_scott_pearson
Super User Retired Employee
This is a bug in the program. Intel is working on a fix. In the meantime, if you install something and it comes back and say it still needs to be installed, then just ignore this notification.
Agustav
Thanks N.Scott.Pearson! Could it be that Intel engineers just mistake files in the zip archive?
Please take a look at that bug:
Thank you!
n_scott_pearson
No, no mistake. The issue is that, in any packages that contain multiple drivers or multiple versions of a driver, the version numbers for these drivers will not match the version number of the overall package. The tool ends up comparing a driver version number to a package version number and this usually results in it thinking the package needs to be installed when it doesn't. As I said, Intel is presently working on a fix for this issue.
