Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13519 Discussions
I get a error when I try to connect to my NUC to my iphone X using bluetooth. Iphone says "not supported". Is this true or some other issue. Thanks
ELarr1
AlHill
Which Nuc?
What processor model number?
What operating system? What VERSION number?
Doc
ELarr1
Hi Doc,
NUC8i7BEH with Windows 10 pro.
ELarr1
iphone software version 12.2
AlHill
But, which VERSION of Windows 10? Go to start, settings, system, about, and go to the bottom of the page to find the information.
Doc
ELarr1
Alberto_R_Intel
ELarr1, Thank you for posting in the Intel® Communities Support.
In order to try to fix this problem, we can try to disable and re-enable the Bluetooth feature in the BIOS:
1.Press F2 during boot to enter BIOS Setup.
2.Go to Advanced > Devices > Onboard Devices.
3.Uncheck the box to disable Bluetooth.
4.Press F10 to save and exit BIOS.
5.Shutdown the Intel NUC.
6.Remove the power cord from the Intel NUC, then reconnect it.
7.Turn the Intel NUC back on and press F2 during boot to enter BIOS Setup again.
8.Go to Advanced > Devices > Onboard Devices.
9.Check the box to enable Bluetooth.
10.Press F10 to save and exit BIOS.
11.Shutdown the Intel NUC.
12.Remove the power cord from the Intel NUC, then reconnect it.
13.Turn the Intel NUC back on.
We can also try to install the latest Intel® Bluetooth driver version 20.120.2:
https://downloadcenter.intel.com/download/28595/Intel-Bluetooth-Technology-Based-Driver-for-Windows-10-64-Bit-for-Intel-NUC-Products?product=126140
The Intel® NUC Kit NUC8i7BEH works with Intel® Bluetooth version 5.0, since the error message is showing on the phone, did you check with the manufacturer of it to confirm which is the Bluetooth version the phone is using and if it is is fully compatible with the Intel® NUC?
Are you able to connect another Bluetooth device to the Intel® NUC?
Alberto R.
Under Contract to Intel Corporation
Alberto_R_Intel
ELarr1, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
ELarr1
Alberto,
I have yet to Solve the problem but I haven’t contacted Apple about the issue.
Alberto_R_Intel
ELarr1, Thank you very much for letting us know that information.
That will be a good thing to do, Apple might have further suggestions on this matter.
Did you try the steps provided previously?
Alberto R.
ELarr1
Alberto,
Yes I have a Bluetooth mouse and keyboard connected with no problem.
Alberto_R_Intel
Based on the fact that there are two other Bluetooth devices working with the Intel® NUC Kit NUC8i7BEH it indicates that the Bluetooth feature and the Intel® driver are working properly.
This could be related to a compatibility problem between the Intel® NUC and the iphone X, at this point and in order to confirm that information we recommend to get in contact directly with Apple for them to verify those details:
https://support.apple.com/
Alberto R.
Alberto_R_Intel
ELarr1, I just wanted to check if you were able to to get in contact with Apple support to confirm if there is a compatibility problem between the Intel® NUC and the iPhone X and if you need further assistance on this matter?
Alberto R.
Alberto_R_Intel
ELarr1, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
