Intel® NUCs
12305 Discussions
I have disabled Bluetooth in the Intel Nuc Bios, but in Windows 10 it is still on, when I scan Bluetooth devices with my phone, it is still found it seems that windows 10 overides the Intel Nuc Bios is this a bug ? Is there a Bios updat for this?
sneka
NUC8i5BEH2
LeonWaksman
  1. Since the Bluetooth radio, uses the same Wireless Adapter with WiFi, probably you need to disable also the PCIe Port in M.2 Wireless Slot (For WLAN) as well.
  2. Other possibility to make hide your NUC and to make it invisible for Bluetooth devices is setting in Windows. Switch Bluetooth to OFF.
Leon
sneka
Thank you,
You say:
But I have an ssd installed in the M.2 Slot if disabled then the ssd wil no longer work or is this another slot?
In windos 10 I have already disabled the the switch but when windows wake up from sleep Bluetooth pops up again.
LeonWaksman
  1. The M.2 slot for Wireless adapter is not the same M.2 slot as for SSD. Usually the Wireless Adapter is installed in separate M.2 slot . In case of your NUC8i5BEH the Wireless Adapter is a soldered down package instead to be installed in M.2 slot as in other NUCs. This probably was done for costs and/or space saving. I don't have NUC8i5BEH, so I can't check what is exactly the function label in Bios. Any way, my advice is similar. The same what you did in bios for disabling the Bluetooth function, do with the WLAN function. Both functions are served by the same adapter.
  2. Did you tried switching the Bluetooth OFF in Windows settings?
Leon
sneka
In Bios:
Bluttooth disabled
Wlan disabled
In Windows 10 I have removed all Bluetooth devices
when I scan with my phone, it finds a number of Bluetooth devices without names but only numbers, then the number of devices is reduced.
It looks like it's not being turned off properly
because there is still Bluetooth signal, only without device name
When I completely turn off the Intel NUC, the Bluetooth devices that I have found earlier in my phone disappeared, I have tested this several times
Wanner_G_Intel
Hello sneka,
For testing purposes, we did the following:
1. Disabled Bluetooth in Windows*. We noticed a Bluetooth address was showing.
2. Entered BIOS and disabled both Bluetooth and WLAN.
Devices > Onboard device Config > Bluetooth
Devices > Onboard device Config > WLAN
No Bluetooth address was listed in the device (Phone).
3. Turned off the unit. No Bluetooth address was visible.
If WLAN is enabled in BIOS, other Bluetooth devices may detect the Bluetooth radio address even if it is turned off in Windows, as addressed by LWAKSMAN. Having said that, we consider this expected behavior.
Wanner G.
Under Contract to Intel Corporation
sneka
Is the Bios version perhaps the problem?
This is my bios version:
Desktop Board NUC8BEB
Bios version: BECFL357.86A.0041.2018.0719.1931
By the way, is it recommended to update?
Leonardo_C_Intel
Hello sneka
Let us confirm what is the BIOS version used during our testing, We will be posting back as soon as possible.
Leonardo C.
Wanner_G_Intel
Hello sneka,
We do not consider this to be a BIOS issue. However, we performed these steps on units with BIOS version 0054 and 0057. We also recommend having your system up to date.
Wanner G.
sneka
Where can I download the Bios for my nuc?
I can only find this:
NUC8i5BEH Bios Version: 0071
but not
NUC8i5BEH2
thanks for your support
n_scott_pearson
Super User Retired Employee
@sneka​,
The '2' in your NUC's name is simply an indication that the EU power cord is provided with your NUC (see Intel NUC Power Cord Options for more information).
You should be using the BIOS that you found, namely that indicated for the base designation "NUC8i5BEH".
Hope this helps,
Wanner_G_Intel
Hello sneka
Were you able to update the BIOS firmware on your unit?
F7 BIOS Update Instructions for Intel® NUC
If you need further assistance, please let us know.
Wanner G.
Wanner_G_Intel
Hello sneka,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Wanner G.
