Intel® NUCs
12121 Discussions
I have nuc7i5bnh with one unit of Crucial 16GB DDR4-2133 SODIMM CL15 (CT16G4SFD8213.C16FBR1) and one unit of Intel SSD 600p installed.
SChew3
I intend to buy one more unit of DDR4 RAM. What is the recommendation? As I checked online, most of the RAMs are 2400. If I buy 8GB DDR4-2400, is it compatible with the current 16GB DDR4-2133? or do I have to buy 16GB DDR4-2400 instead of 8GB? Any problem if memory size is different? Please advise. Thanks.
AlHill
It is ALWAYS best to have MATCHED pairs of memory. ALWAYS.
Doc
LeonWaksman
If you will install different (in size, frequency or P/N) memory module, your computer will not work in double channel memory mode (i.e. lower performance). If you will install similar module, you have good chance that the computer will work in double channel memory mode. I say, you have good chance, because to ensure it, you should install memory kit (two identical memory module, chosen in manufacture). On ebay you may find memory you need: https://www.ebay.com/itm/Crucial-16GB-PC4-2133-Laptop-RAM-SODIMM-CT16G4SFD8213-Memory-100-Tested-Gra... . This is not endorsement to buy from this seller, but example only.
Leon
SChew3
thanks for prompt response. It's difficult for me to buy from eBay. Is it possible to buy this model Crucial 16GB DDR4 2400Mhz Sodimm Value Ram - CT16G4SFD824A? Everything is compatible except it's 2400MHz. According to Crucial web site, it can support 2133MHz.
AlHill
You may get lucky with mixing memory, but it is not recommended.
Doc
