Community
cancel
Showing results for
Search instead for
Did you mean:
AWall2
I have problem booting an Ubuntu usb to start an installation process
NUC 5i7RYH
Kingston G4 8GB USB created by Standard Ubuntu USB-utility with Ubuntu 17.04
The USB is found by BIOS but it won't boot from it.
I have tested several BIOS settings and updated BIOS Firmware too.
Any ideas?
Community Manager
Hello aw_kreawit
Thank you for reaching the Intel Communities.
I understand you are trying to boot the system to a USB installation media for Ubuntu*
For sure we can check on some troubleshooting for that matter.
  • Have you tested with different programs to create the bootable USB?
  • Are you getting any sort of message while trying to boot from the USB?
  • Have you tested different USB ports?
  • Have you tested different ISOs for your OS?
  • Have you tested the behavior with a Windows-based bootable USB?
Esteban C
AWall2
Yes, rufus and a debian netinstall iso
No, when I use F10 and choose an USB option it just return to the menu without any message
Yes, and with different USB-pins too (USB2/USB3). I read about someone that had trouble using a wireless usb-keyboard at the same time as he tried to do usb-boot, some sort of interference I believe. I have not figured out how to boot on usb without the keyboard, so Im stuck with my wireless Logitech.
Yes, 17.04, 16.04LTS and debian netinstall iso
No, I don't have any knowlage to create a Windows based USB (and I have no Windows at all)
Community Manager
Thank you for reporting back, aw_kreawit
Do you have the option to test the system with a wired keyboard? Or another wireless keyboard?
If you have access to the BIOS, please make sure you have the latest version installed (0366)
You can download it from here: http://intel.ly/2zgUm2A http://intel.ly/2zgUm2A
It is better to use the F7 BIOS flash update noted here: http://intel.ly/2yQeJHT http://intel.ly/2yQeJHT
Please let me know how it goes afterward.
Esteban C
AWall2
Sorry, I got rid of all my wired ones.
Yes I have tested with the latest and even tried some old.
No, luck
LeonWaksman
Try the following:
- Please check if this USB is bootable on other PC. If it is not booting, prepare new installation media and enter boot menu by pressing F10.
- Enter Bios setting and press F2 to set bios to default settings and then F10 to save the defaults settings.
Hope this will help
Leon
AWall2
Try the following:
My other PC does boot with all media I have tried on the NUC
I have tried that to.
Other thing I tested: I invested in an ICY BOX for the M.2 SSD and installed an Ubuntu 17.10 from another computer. The new disk boots other computers but not the NUC. I have tried to boot with and without security boot in BIOS and I have cleared certificates, it looks like it won't boot on media with Ubuntu on, USB or M.2. I fetched and installed Windows 10 on the M.2 and its boots, when I reinstall Ubuntu it does not.
AWall2
I have now reset the BIOS (removed battery), booted without the jumper and reset what i found, installed a new BIOS and loaded default settings (F9).
Booting with only legacy boot:
Now I can boot and install Ubuntu 16.04 or 17.10 on the M.2, not using F10 (F10 does not see the USB) but wait for standard boot. But I can't boot on the newly installed M.2 (which I believe needs EFI too boot?)
Booting with EFI and legacy boot ticked:
Now I can boot and install Ubuntu 16.04 or 17.10 on the M.2 again, not using F10 (F10 does see the USB as EFI-devices but does not boot from them). But I still can't boot on the newly installed M.2, I think the resulting installation is "legacy"
Booting with EFI-only:
F10 sees my USB-thumbdrives but can't boot from them, waiting does not finds any devices to boot from.
Community Manager
Thank you for the information provided, aw_kreawit
I was wondering, were you using UEFI with the other computers that were mentioned (the ones working with Ubuntu 17.10)
Esteban C
Community Manager
Hello aw_kreawit
This is to do a follow up to your post and find out if you were able to check my previous answer.
Esteban C
AWall2
Yes, Esteban, I have installed Ubuntu using UEFI on the other computers I have tested. For example a NUC7I7BNH worked like charm.
Community Manager
Hello
Thank you for the answer provided.
I went ahead and did some tests with an Intel® NUC Kit NUC5i7RYH, 8GB of RAM and M.2 SSD
Used Rufus to create the bootable USB with the ISO available at https://www.ubuntu.com/download/desktop https://www.ubuntu.com/download/desktop
After that, I loaded the default settings at the BIOS, then started the installation process (F10, select UEFI, and got Ubuntu's installation window)
Then got it setup and running normally.
I will add some screenshots as proof and also for you to compare with the BIOS configurations on your system.
Additionally, when you said "But I still can't boot on the newly installed M.2, I think the resulting installation is "legacy"
Did you get any sort of error message while trying to boot with that M.2?
The problem was not present in my lab, so I want to find out what is different from the 2 configurations (yours and mine).
Esteban C
Community Manager
Hello aw_kreawit
This is a follow up to your post in order to find out if you were able to get the system working as desired.
Esteban C
AWall2
I will check my configuration with your screen dumps...
Community Manager
Sounds great, aw_kreawit
Thank you for reporting back, I will keep the thread handy to get those results.
Esteban C
