Intel® NUCs
Assistance in Intel® NUC products
13309 Discussions
I have the Intel NUC 7i5bnh with a intel Dual Band Wireless-AC 8265, I can't browse through the internet on 2.4 g wifi networks. On 5 g it works fine. Any idea?
Mariusku
It does connect to the 2.4 g but no internet, other devices on same 2.4 g wifi work perfect...
LeonWaksman
This adapter has two antennas - one for 5GHz radio and the other for Bluetooth an 2.4GHz radio. Check if the antenna cables are firmly connected to the AUX connector. I assume that you have also problems with Bluetooth communication. The AC8265 is located under SSD drive. So in order to get access you need to remove the SSD first.
Leon
n_scott_pearson
Super User Retired Employee
Also, have you checked your router configuration? It is possible that sandboxing is taking place.
Mariusku
Bluetooth working fine.
How do I check the sandboxing option of my router?
LeonWaksman
  1. No need to open second thread in the same subject.
  2. Please see my answer in the second thread https://forums.intel.com/s/question/0D70P000006TZbiSAG
Leon
