Intel® NUCs
12325 Discussions
I have two Intel NUC NUC8i3BEH. Love them. One of them has a second LED on the front panel. What does it indicate?
SteveMann
LeonWaksman
This is Drive Activity LED. Indicates that the drive is boeing accessed.
Leon
LeonWaksman
Leon
SteveMann
Thanks. Is this documented anywhere?
LeonWaksman
It is documented very bad. In some "hidden way". See the Technical product Specification , page 29, figure 9, Item F.
Leon
SteveMann
Thanks- I had not seen that document.
You would think I would have learned- my second programming job was writing and supporting an embedded processor using the Intel 8080. For 17 years. Even then finding the data from Intel was a challenge. (Before the Internet, of course).
I've copied the PDF. thanks again.
n_scott_pearson
Super User Retired Employee
Note also that you have control over how the LEDs are used. Go into BIOS Setup and select Advanced and then Power. In the Secondary Power Settings, you can select the function, color and display mode (solid, flashing or pulsing) for each of the LEDs.
