Intel® NUCs
12325 Discussions
I having a problem with 4 pin front fan,i got new fan,working fine outside, by using usb cable adapter,the only stop the error is the jumper. Any help?How do I testing the pin? Pllease note the pin are good not damaged or some.
tVend1
Only i done is by removed the GPU Quadro and using Radeon pulse sapphire 4gb. But this GPU radeon got different speed control than hp workstation,so i used it only about 10 days and now i reinstalled the Quadro K4000 3GB.So the problem start when i switch the GPU.
AlHill
Download, run, and ATTACH (using the paperclip under the toolbar) the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Doc
tVend1
