Intel® NUCs
12110 Discussions
I need a power connection cable between a normal Sata drive and the Intel NUC 3815 TYBE motherboard. Where can I get it?
freewarehookie
n_scott_pearson
Super User Retired Employee
You can purchase this cable through MicroSATACables. See this page: https://www.microsatacables.com/intel-nuc-products/intel-nuc-cables
freewarehookie
​Is this cable and the board capable of powering a SATA HDD - Hard Disk Drive?
Otherwise the cable would be of no use.
n_scott_pearson
The circuit is designed​ to provide enough power for a 2.5" SSD/HDD/SSHD. If this is what you have, then you are good to go. If your goal is to connect a 3.5" SSD/HDD/SSHD, however, this is problematic; most require more power than is provided here (look at drive specs; especially power-on surge requirements).
freewarehookie
