Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13490 Discussions
I need a replacement power supply for my Intel NUC
PBair
I have an Intel NUC, s/n: G6BN748008CP
It's missing it's power supply.
Can you supply? Or can you advise where I can source a replacement power supply?
Thank you.
AlHill
What is the model number of your NUC?
Doc
PBair
Thanks Doc. I can't check the model number of the NUC just now. Can you chac kit using the serial number: G6BN748008CP?
AlHill
Just look on the bottom of your NUC, or you look up the model number.
Doc
PBair
I'm working from home, and the device is in the office, but I'll be in the office tomorrow and will check that. Cheers.
PBair
I think it's an 8NH, based o a record I have that says "NUC 7i78nh i7" Does that make sense?
LeonWaksman
  1. You have probably NUC7i7BNH
  2. This is an example where you can buy replacement Power Supply : from Simply NUC, however, you may find compatible Power Supply on Amazon.
Leon
n_scott_pearson
Super User Retired Employee
You can determine your NUC;'s family from your Serial Number. The third and fourth characters in the Serial Number indicate the family of the NUC. This, it identifies that you have a BN NUC.
The BN NUCs ship with a 65W power supply. There are *many* compatible power supplies available through Amazon and most are in the US$12 - US$20 price range..
PBair
Thanks for the advice folks, much appreciated.
JessicaJ
The 7th gen series use a standard 19V 65W power supply with a 5.5mm x 2.5mm barrel connector.
While there are plenty of compatible power supplies available on Amazon or eBay cheaply, the important things to watch for are:
  • Voltage: must be 19V
  • Wattage: must be equal or greater than 65W (or amperage equal or greater than 3.42A, because volts * amps = watts)
  • Connector must be 5.5mm x 2.5mm -- this is important, as there are a fair number of supplies with 5.5x2.1 connectors but those won't fit
Honestly you can just omit the wattage or amperage in the search, and try just "19V 5.5 2.5", the relevance of those results is pretty spot on -- just double check the wattage/amperage in the description (there are lots of 90W supplies, those will work perfectly fine too) and make sure the description also mentions something like "Connector tip: 5.5/2.5mm" (might also be listed like "5.5x2.5" which is why I just suggest searching the raw numbers).
PBair
Thank's for all your answers Leon, Scott & Jessica. I'm now happily sorted.
Regards. Paul.
