The components that the sensors monitor include memory (RAM), processor (CPU), platform control hub (PCH), and voltage regulator (VR). VR temperature, means Voltage Regulator temperature. For more complete explanation, please read here: https://sites.google.com/site/visualbios/advanced/cooling/temperatures
Leon
Now I understand better your question. On the left panel, near the temperature graph, you can see label marked VR temperature (which means Voltage Regulator temperature), however on the R.H side panel, there is not possibility to chose VR temperature sensor. VR temperature sensor measures temperature on Voltage Regulator, while Processor Temperature Sensor measures temperature on CPU core (which is other place). Probably there is an error in the bios label, which should be CPU temperature, rather than VR temperature.
Wait for confirmation from Intel's agent. He will probably answer on Monday.
Leon
Thank you for the reply. Are you telling me there is no cpu temperature reading in the bios?
Well that is shocking.
Hi @fadsarmy
Don't be shocked. This reading is not important as you think. As I've wrote you VR means in this case Voltage Regulator. I still think that this is an error in bios label and the temperature shown is for CPU (I can't be sure, since I don't have NUC8i5BEH). Any way any temperature reading shown in bios is not indicative for the temperatures under the O.S. regime with real load. So better download free application, for example HWMonitor https://www.cpuid.com/softwares/hwmonitor.html and you will be able monitor you NUC during operation.
Leon
There is no cpu temp in bios. I always knew what VR Temp was but I was so surprised that cpu temp was absent, I though maybe Intel found a new name for it. They have silly things like memory temp but no cpu temp. Shocking, unbelievable.
However in the subject you wrote: "What is this VR temperature? Is it the same as cpu temperature?" 😊
Leon
Well I was so shocked that maybe Intel call the cpu temp vr temp or they labelled it wrong. Can't put anything past Intel with them leaving the cpu temp out. BTW, it's one noisy unit.
The BE board monitors five (5) temperature sensors, Processor Temperature, PCH Temperature, VR Temperature, Memory Temperature and Motherboard Temperature. The VR, Memory and Motherboard temperatures are measured using thermal diodes placed in specific locations on the board. In this case, they are located next to the VRM, below the SODIMMs and below the M.2 SSD. The Motherboard Temperature sensor is best sensor to use to measure whether there is sufficient airflow over the board's lower surface. It and the sensor in the M.2 SSD (exposed via S.M.A.R.T.) should be used together to determine whether M.2 SSD is receiving sufficient cooling. Aside: Because of the thermal foam placed against the top of the M.2 SSD (and which is being used to dissipate the heat from the M.2 SSD into the chassis (K units) or drive bay (H units) metal), the air flowing over the surface of the board ends up being funneled under the M.2 SSD and over the thermal diode. Hence its importance.
As for the BE BIOS, its sensor display (incorrectly, I agree) does not include the Processor Temperature in the graphs displayed. You will note, however, that the Processor Temperature is the default selection for Primary Temperature for fan speed control (as it should be). As I said, the best selection for Secondary Temperature is the Motherboard Temperature sensor. Aside: I agree that 'Motherboard Temperature' is not the most elegant of names, but it is measuring the (Mother)board temperature in an important location.
P.S. Note that the Processor (once they fix the BIOS), PCH and VR temperatures displayed within Visual BIOS should not be used to determine temperature coefficients for fan speed control. While running Visual BIOS, all power management features of the processor are disabled and thus temperatures will be higher than what you will see in runtime environments.
