Intel® NUCs
12097 Discussions
I think I restart NUC with wrong BIOS settings and i see this picture. I cant change BIOS settings because i can not see. How can I fix it?
IPost1
LeonWaksman
Hello @IPost1​
  1. Probably you have changed some graphics setting. This is not necessary, leave those setting default. The Windows will take care for assigning correct amount of graphic memory.
  2. In order to fix this please follow the following steps:
2.1 While NUC is powered OFF, press and hold the Power Button. Count 1001, 1002, 1003. 1004 and release the Power Button.
2.2 NUC should boot into Power Button Menu.
2.3 While you see the POwer Button Menu, press F2 to enter BIOS settings.
2.4 Press F9 (confirmed by "Y"), to set BIOS to default settings
2.5 Press F10 (followed by "Y"), to exit bios and boot to Windows.
2.6 Now if you want, you may enter BIOS again and perform your requested changes in settings. However, do not change graphics settings. Those settings are used in BIOS only.
Leon
