Intel® NUCs
12298 Discussions
I want to know if a NUC 8 with an I5 can play online games and streaming of the game online and not over heat or burn up the video card.
Charles_B_Intel
If the NUC burns up and is under warranty but I played too many games and burned it up is it covered under the warranty?​
AlHill
Well, "burns up" is a bit harsh, is it not? The NUC is not going to heat your home, but it will get "warm". Just keep it clean, and provide adequate ventilation, and you will be fine.
You can play as many games as you want, and are supported on the NUC with Windows 10.
Used properly, your NUC is under warranty.
Doc
