Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11991 Discussions
I was trying to enable PXE boot Haydes Canyon NUC, but it does not seem to go into the PXE Firmware, it is Available in any version of Firmware?
Rakesh_D_Intel
Wanner_G_Intel
Hello RDode,
Thank you for posting on this Intel Community.
To better assist you, we would like to know the following information:
1. BIOS version
2. Operating system (if applicable)
3. Are you booting from the onboard LAN or a network add-in card?
Wanner G.
Under Contract to Intel Corporation
Wanner_G_Intel
Hello RDode,
If you need further assistance, please let us know.
Wanner G.
Rakesh_D_Intel
I am using the Latest BIOS
I am trying to PXEW boot and Install the OS from a PXE server. the OS I want to install is only available to me on the PXE server I have setup
I am trying to use the Built in Network control er on the Haydes Canyon Intel NUC Intel® NUC Kit NUC8i7HVK
thanks
Rakesh
Wanner_G_Intel
Hello RDode,
Thank you for your response.
By latest BIOS, we assume that you are running BIOS 0057
We will investigate this issue further and get back to you soon.
Wanner G.
Wanner_G_Intel
Hello RDode,
First, it is worth mentioning that all BIOS firmware versions for this unit support PXE boot.
Please check these BIOS settings:
  1. BIOS > Advanced > Boot > Boot configuration > Uncheck 'Boot Network Devices Last'.
  2. Then, go to Boot configuration > Network Boot > 'UEFI PCE & iSCSI'
  3. Enable 'Ethernet1 Boot' or 'Ethernet2 Boot'
If the issue persists, please check the server configuration.
Wanner G.
Wanner_G_Intel
Hello RDode,
Were you able to check the BIOS settings recommended to network boot?
Wanner G.
Rakesh_D_Intel
yes I was able to PXE boot, thanks
Wanner_G_Intel
Hello RDode,
We are glad to hear that the issue was resolved.
We are going to close this inquiry. If you need further assistance, we will be glad to help you.
Wanner G.
