Intel® NUCs
12145 Discussions
INTEL-BOXNUC7I3BNH does it supports 2666hz memory
JLuza
hi there, i need some help, does the 2666hz memory will work on INTEL-BOXNUC7I3BNH? anyone? thanks in advance..
LeonWaksman
In the following table you may found the tested and approved memory modules. 2666MHz is not among them. The memory with highest frequancy tested was memory 2400MHz and will run only at speed 2133MHz.
http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC...
Leon
JLuza
thank you very much sir. i appreciate it much.
