1. Wht if any intel product is not working after warranty, we shud through it in dustbin. No person is taking or understanding outside service technician. Can some one guide me regarding this,
I want to provide onsite paid service. Pls reply intel.
Hello @Ksr,
I understand that you are looking for support regarding the issue. However, I did not provide any troubleshooting steps as @LeonWaksman provided some valid recommendations for your issue, I advise you to take a look at his comment above and let us know the outcome.
Jean O.
Hello @Ksr
Could be that the CMOS battery in your NUC is discharged and should be replaced. You should check the voltage on the battery connector (it should be 3V at least). In order to reach this battery and its connector, you need to remove the board from the NUC case, since it is located on board upper side. If you have some technical skills, you can do this following this guide.
This is an example for replacement CMOS battery.
Leon
Hello Ksr,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues with your Intel® NUC Kit NUC8i3BEH not powering up.
It is important to mention that Intel does not support paying to extend the warranty of a product for which the warranty already expired.
I will reach out to you privately with further details about your issue. I would send you an Email to the address associated with your profile.
Jean O.
Hello @Ksr,
Jean O.
Hello Ksr,
I appreciate your response.
Based on the information, I assume that the local technician means that the issue is due to the power adapter of your unit. However, there is no option for you to buy on your local market; is this assumption correct? If not, provide me with more details about the information your local technician shared with you.
Jean O.
Hello Ksr,
I hope you are doing fine.
Jean O.
Hello Ksr,
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
