I have INTEL NUC BOXNUC8I7HVK2 when turbo boost run, run simple google chrome and cooler rotates where fast with loud sound 5-10 second then everything is quiet. If i'm off turbo boost the cooler practically does not spin and the system works very quietly. This is normal? It turns out in the turbobus mode the launch of almost any application includes a strong rotation of the cooler?
What are the cooling setting in Bios ? My NUC8i7HVK works quiet and steady with Turbo Boost enabled. Such behavior of cooling (cooling fan speed fluctuation) fan I've observed in NUV7i7DNHE, however, not in NUC8i7HVK.
Leon
Do you also have Max Performance Enabled checked? If so, try unchecking this and then checking Balanced Enabled. Similarly, in Windows, run the Control Panel Power Options applet and select the Balanced plan.
Bios cooling settings is Balanced
When in the Windows power settings I select 99% CPU max everything becomes normal and the cooler rotates almost silently
Please download Intel System Support Utility (SSU) https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- . Run the SSU Scan, save the results and using "Paper Clip", attach the file with the results to your post.
Leon]
Leon
Thank you for your advice. I reset the power settings in both BIOS and Windows now everything is fine.
I'm glad that I could help. Enjoy you NUC.
Leon
