Community
cancel
Showing results for
Search instead for
Did you mean:
mclar10
INTEL® NUC NUC8I7HVK Help
Jump to solution
hello,
I am thinking about buying a INTEL NUC8I7HVK. It will be my first barebone pc and im a little confused on what i need to buy with it.
hubick
New Contributor II
You will also need memory/RAM (DDR4, laptop style SO-DIMM form factor, 2400 speed or faster), and a hard drive (an SSD in the M.2 form factor, up to 80mm long [most are that "2280" size], PCIe/NVMe [fast] or SATA [slower] interface).
hubick
New Contributor II
MLevi
Valued Contributor I
You can pick these units up fully configured too (with your specifications).
I purchased mine from SimplyNUC.
LeonWaksman
Hello matthewrkc ,
In the following list you will find list of tested components and peripherals for your NUC: http://compatibleproducts.intel.com/ProductDetails/ExportPeripheralInfo?moduleName=Intel%C2%AE%20NUC... Intel® Product Compatibility Tool . If you will buy a memory and drives from this list you will have no surprise since it was tested and approved by Intel. Of course you will need also buy a license for Windows 10 64bits.
Intel drivers for uour NUC you may download here:https://downloadcenter.intel.com/product/126143 Downloads for Intel® NUC Kit NUC8i7HVK
In the following link you will find all additional information: https://www.intel.com/content/www/us/en/support/products/126143/mini-pcs/intel-nuc-kits/intel-nuc-ki... Support for Intel® NUC Kit NUC8i7HVK
Hope this will answer to your quastion
Leon
NStei5
Just ram and m2 ssd
