Intel® NUCs
Assistance in Intel® NUC products
12946 Discussions
Install clear linux
Tiw
Hi , have a slight problem installing clear Linux from usb.Gives me this error code
AlHill
What is the model number of your NUC>
[Waiting for Windows 12]
Tiw
Hi thank you.Is a nuc11Thni7000.but should you have an admin password on the NUC bios thanks
Tiw
hi,so all passwords installed on nuc but same problem .it says to check the file but cannot log in as root.is there a root ps for the iso image.thanks
JosueO_Intel
Hello Tiw,
Thank you for posting on the Intel communities.
In this case, we recommend checking with your Linux distro's website and forums to get assistance with the installation of the OS.
Hope this information is useful, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Josue O.
Tiw
Hi thanks.Well it’s the Intel clear Linux. The iso loads fine and works very good.It is the install on the very end that gives the last error about check admin code. But there does not seem to be a password to access admin ?.It’s getting hung up on 1stupid thing before final hd install.
