Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13496 Discussions
Installation of BIOS update BECFL35357.86A does NOT Succeed.
AMond12
The system requests reboot again and again, but installation fails.
LeonWaksman
What is your NUC model? Could be that you mean BECFL357.86A for BE NUC?
Leon
TPerk4
I am also having a problem with updating the BIOS. BECFL357.86A.0079 for a NUCI3BEH. I have updated many times and never had this issue. I have the BIOS on a FAT32 formatted USB, I reboot to BIOS and press F7, choose the correct device, select the BIOS file. The system reboots once, nothing happens, reboots again and boots back into Windows.
AC4
same issue here and in device manager it also reports error
LeonWaksman
AC4
no luck bios recovery and bios flashing will not install this bios, it doesnt even error it just does not go on at all
TPerk4
No luck here either. Followed Leon's instructions to the letter. Recovery didn't appear to do anything, just a blank screen after pressing F4, about 30 seconds and the computer rebooted to Windows. Went ahead and tried installing BIOS again in the Yellow USB slot, made no difference.
LeonWaksman
I'm waiting for response from Intel engineering.
Leon
BWils22
Same issue here. Performing the BECFL357.86A BIOS Update on a NUC8i7BEH (to go from v1538 to 1838). It seems to go through the motions of performing the update, but when I reboot, the Intel Driver & Support Assistant indicates that the computer still has the old BIOS, and it's still prompting me to perform the update. I've followed up with a restart, to no effect. After that, I tried using the other update methods. MSI installer also went through the motions but failed to actually perform the update. Likewise, the F7 method didn't work either. I haven't had any issues completing BIOS updates on this computer before.
Wanner_G_Intel
Hello all,
Thank you for posting your question on this Intel® Community.
We still do not have confirmation of the Intel® NUC model and the BIOS version AMond12 is having issues with. At this point, the issue you are having with BIOS update 0079 is a new issue. Intel Customer Support usually addresses a question/issue in each thread.
Our recommendation is that you start a new thread including the steps you have tried to resolve it. We will be glad to look into this BIOS update problem.
On the new thread, please provide the following information:
  • Run the Intel® System Support Utility (Intel® SSU) and attach the report to the thread
  1. Intel® SSU Download link
  2. Open the application and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  3. Click on the menu where it says "Summary" to change to "Detailed View".
  4. To save your scan, click on "Next", then "Save".
Also, please provide a description of the issue and the exact BIOS update method you are using.
If possible, provide pictures of any error messages being displayed in Device Manager.
Hello AMond12,
Could you please provide us with more information about your system configuration? If you are experiencing the same issue, please provide the report and details requested above.
Wanner G.
TPerk4
Wanner G, please find my SSU information. Let me know if I should create another topic for this issue.
Hotshot
Wanner G, please find attached my SSU output. Same behavior going from version BIOS 0078 -> BIOS 0079 . Installation start , then restart the NUC as planned, but installation of the bios after seem to be skypping and go back to windows 10 boot without any message from the Bios boot screen. Use windows installation method and BIOS update (F7) method to update without succes. In device manager, I see under Firmware menu this warning in device status under BE0079 : "This device cannot start. (Code 10). Indicates a revision number encountered or specified is not one known by the service. It may be a more recent revision than the service is aware of" . In BIOS, version is stil 0078 after installation tentative. Model NUC8i5BEH. I just update to version 0078 early this week which work without any issue, only the new version 0079 posted is not working.
Hotshot
Wanner_G ; is this work around can be confirm by Intel ? see thread https://forums.intel.com/s/question/0D70P000006i6aJSAQ
AMond12
https://forums.intel.com/s/question/0D70P000006i4zRSAQ
  1. Attached SSU - Arik file.
  2. I am using the Intel Driver & Support assistant for BIOS updating.
  3.
AMond12
Arik Device Manager
AC4
thanks for the post i have the same issue here
Wanner_G_Intel
Hello AMond12,
Thank you for your response.
It seems that the report generated by the Intel® SSU was not attached to the thread. Could you please attach it directly to the thread using the "attach file" option?
Also, thank you all for providing detailed information about this issue. It seems that there is no need to start new threads.
We will provide an update as soon as possible.
Wanner G.
TPerk4
Ronny_G_Intel
Community Manager
Hi everyone,
Thank you all not only for reporting but mainly for your patience and my apologies for the inconvenience caused by this issue
We found an issue that when updating to BIOS version 0079 the system initiates the update process but it cannot be completed, this happens if "Secure Boot" option is enabled in BIOS. We were able to recreate this scenario but I also have reports that even with "Secure Boot" disabled, the issue still persists.
BIOS version 0079 is being removed from the Download Center and will be replaced with a version that allows the update with “Secure Boot” option enabled.
While BIOS update to version 79 can be executed with “Secure Boot” option set to disabled, I would recommend that you wait until we release a more recent BIOS version for your system.
Please stay tuned for more updates.
Ronny G
MRoss5200
Valued Contributor I
I tried updating using the EBU file and the BIO file and both fail. If you used the EBU file and the system keeps trying to re-flash on reboot, go into the Device Manager and delete the FIRMWARE item for BE0079. This should be yellow banged because of the failure. Make sure to check the box "delete the driver software for this device" so it does not get reinstalled on next boot. This should fix the re-flash cycle.
Looks like we will have to wait for an updated BIOS from Intel.
