Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Intel DB75EN Motherboard VR Temperature Warning 90-120C, is it normal?
Yesterday i bought Intel DB75EN with i5 3450 processors, with high processor usage the intel dekstop utility keeps me warning about the high VR Temperatures, Voltage regulator temperature i guess? At idle it stays 30-40C but with high processor usages it jumps to 90-125C and i am afraid it isn't somewhere between normal temps! Any help?
Intel i5 3450 3rd Generation
Intel Board DB75EN
Corsair 8gb Ram (4*4)
I have installed two 12mm Side and Rear Cooling fans! Any help?
Tags (1)
Highlighted
Community Manager
1 View
Re: Intel DB75EN Motherboard VR Temperature Warning 90-120C, is it normal?
are you using the Stock Intel Heatsink\fan? what are your CPU temps?
Highlighted
Community Manager
1 View
Yes i am currently using stock fan, CPU/Processor temperatures remains 40-50C!
PCH Temperature around 40C
Memory 30-33C
Idle Processor temperature 30C
Maximum Usage Processor temp 55C
Maximum Temperature at full usage for VR Jumps to 110-120
Idle processor usage VR Temp 30-40C
Highlighted
Community Manager
1 View
that's weird, usually the stock intel heatsink fan does a good job cooling the VR.
Try another temp. program and see if the reading is the same, also check the reading in the BIOS
Highlighted
Community Manager
1 View
Any recommendations for VR Monitoring tool? Should i update my bios? I am currently using
BIOS Update [ENB7510H.86A]
4/27/2012
0029
Highlighted
Community Manager
1 View
BIOS Update [ENB7510H.86A] - 4/27/2012- 0029
