Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13488 Discussions
Intel Driver Assistant - issues with update
SamRyan
My computer said it had an update recently for the Driver Assistant and to reboot. After doing so, it showed up again and no matter how many times I reboot, its the same.
I have tried to uninstall, however this does not work and it gets stuck.
Any suggestions?
Esteban_D_Intel
Hello SRyan10,
To better assist you please provide the following information:
  • Please provide your computer model.
  • What driver did you install with the utility?
  • Are you trying to remove the Intel Driver Support Assistant or the driver from your computer? Please clarify your concern.
Esteban D.
Intel Technical Support Technician
SamRyan
Hi Esteban
I have the hades canyon HVK.
It’s not the drivers but the assistant program itself. Every time I turn on the computer it says that it has updated and needs to be rebooted. When I do this, nothing happens. When I try and open the program, nothing happens.
I cannot use the assistant any longer and have had to uninstall. Even after this, it won’t work. Up until a few days ago, it was working perfectly.
That is for the latest version 20.4.5.
n_scott_pearson
Super User Retired Employee
I suggest that you try the following:
  1. From Apps and Features, uninstall the existing IDSA installation.
  2. Clear your browser cache.
  3. Reboot.
  4. Open https://downloadcenter.intel.com and click on the Get Started button to download and (re-)install IDSA.
  5. Test.
Hope this helps,
SamRyan
Hi Scott
Thanks for the comment, unfortunately no good same problem.
Seems to have occured since bio64 upgrade, have even reset this and reflashed.
Esteban_D_Intel
Hello SRyan10,
Thank you so much for your response.
Have you tried removing the tool using the uninstalled software? If not, please check the steps below:
1. Uninstall the existing Intel® Driver & Support Assistant (Intel® DSA) tool in the system using the Uninstaller tool.
2. Download and install the latest Intel® DSA version
Just to confirm, I understand that the message that appears occurs right after the installation of the BIOS 0064 via the IDSA?
Can you please confirm if the BIOS upgrade was completed successfully?
If possible, please provide a screenshot of the message that you get.
Esteban D.
Esteban_D_Intel
Hello SRyan10,
Please let me know if you need further assistance.
Esteban D.
SamRyan
Hi Esteban
None of that worked had to reset pc now it’s working
Sam
Esteban_D_Intel
Hello SRyan10,
I understand that you were able to resolve this behavior on your side by resetting the computer. I’m glad to know that you were able to make it work as expected.
Please let me know if you need further assistance or if you would like to proceed with the closure of this inquiry.
Esteban D.
Esteban_D_Intel
Hello SRyan10,
We have not heard back from you.
As you were able to resolve this behavior on your side we will proceed with the closure of this inquiry.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
