哎,别提了,我也是这样,你回复让我看了白搭,我也是普通用户。错误日志里面显示错误500:没有网络。我不仅把你做的那些步骤都做了,系统都重置了三遍。所以我怀疑是英特尔某个服务被咱们国内的长城防火墙屏蔽了。
你用中文他们说看不懂,我的英文帖子他们又不回复。要不你们去帮我回复一下,让他们看看吧。https://forums.intel.com/s/question/0D50P00004VfNvmSAF/intel-driver-support-assistant-shows-an-error...
Hello 敏周0002,
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool embedded in this Intel Community.
You can try the following steps:
- Uninstall the Intel® Driver & Support Assistant by using the Uninstaller tool.
- Intel® Driver & Support Assistant by using the Uninstaller
- Delete all the log files and make sure you don't see the Intel® Driver & Support Assistant in apps and features. (if you see it delete it)
- Install the latest version of the Intel® Driver & Support Assistant.
If you are getting an error message that Intel® Driver & Support Assistant is blocked you can try the following:
If you are going through a proxy to access the internet, you may need to configure it to allow access. You can check the proxy configuration by following these steps:
- Open the Internet Options control panel, which can be found in the Windows Start Menu.
- Select the Connections tab at the top of the window, and then select the LAN settings button near the bottom of the window.
- If on a company network, and Automatically detect settings or Use automatic configuration script are selected, then you will need to contact your network administrator to allow connections to localhost. If you are not on a company network and these settings are selected, you will need to manually configure the proxy device to allow connections to localhost.
- If the Use a proxy server for your LAN checkbox is selected, make sure Bypass proxy server for local addresses is checked. Click the Advanced button, and in the Exceptions text area, add 127.0.0.1, and then select OK and OK.
As a reference you can check the following link:
https://www.intel.com/content/www/us/en/support/topics/idsa-faq.html#FAQSection1
Adrian M.
A Contingent Worker at Intel
I posted about the same error in English at https://forums.intel.com/s/question/0D50P00004VfNvmSAF/intel-driver-support-assistant-shows-an-error... with DSA logs attached. Please pay attention to it.
Hello 敏周0002,
Thank you for your response.
I can see you shared the log files of the Intel® Driver & Support Assistant on this link https://forums.intel.com/s/question/0D50P00004VfNvmSAF/intel-driver-support-assistant-shows-an-error..., I will further investigate it, please allow me some time to update the thread.
Adrian M.
Hello Adrian M.,
Thanks for your attention, and hope that the issue will be fixed soon. We're looking forward to your reply.
But I'm another user of Intel DSA and have the same problem with Intel DSA as 敏周0002. We met each other on this forum and we're both located in the Mainland of China. :)
Hello 敏周0002,
I would like to update the thread.
This is an issue with the way IDSA checks internet access, which isn't working for PRC. We are still working on this issue.
In case you need to run some updates you can get the Intel driver from Download Center directly.
Adrian M.
It seems that the issue has been fixed in version 19.12.50.5.
Hello QWan01,
Thank you for the update.
I am glad to know that the issue has been fixed with the Intel® Driver & Support Assistant 19.12.50.5 version.
I will share your feedback with the development team.
Adrian M.
