Intel® NUCs
12314 Discussions
Intel® Management Engine Consumer Driver for Windows® 10 64-bit for Intel® NUC Products fails to install the update. Attempts to install fail.
RBush2
n_scott_pearson
Super User Retired Employee
This error message is telling you that the current version's installer was unable to uninstall the previous version. You must manually uninstall this previous version before the newer version will be able to install. If you don't know how to do this, let us know and we will provide help.
ZSari
The same thing with my NUC7i7!?
RBush2
I created a support ticket. I will share the results here when I get them.
n_scott_pearson
RBush2
That is what I did this morning after i spoke with a friend. It worked after i uninstalled the app.
RBush2
The application was uninstalled via the control panel. App reinstalled via download. All is well.
