Intel® NUCs
12337 Discussions
Intel NUC 10 i3 Front Panel Audio
provjswamy
Hi all,
Am trying to setup my NUC10i3FNH and I just could not make the Front Panel Audio to work however I try.
i. Acknowledge it is a genuine problem from Intel's side.
ii. Suggest a sure-fire way to solve it, cause I have lost 2 days of productivity already.
Thanks in advance,
-Vj
Esteban_D_Intel
Hello provjswamy,
To better assist you please provide the following information:
  • Please provide a detailed description of the troubleshooting steps performed so far.
  • When did you start experiencing this behavior?
  • Were any changes made prior to this situation?
  • How many units are affected by this?
Please run the following tool and attach the reports generated.
Intel® System Support Utility (Intel® SSU) Download link
1.Open the application and click on "Scan" to see the system and device information.
2.By default, Intel® SSU will take you to the "Summary View".
3.Click on the menu where it says "Summary" to change to "Detailed View".
4.To save your scan, click on "Next", then "Save".
Esteban D.
Intel Technical Support Technician
Esteban_D_Intel
Hello provjswamy,
Were you able to check the previous post?
Please let me know if you need further assistance.
Esteban D.
Esteban_D_Intel
Hello provjswamy,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
