Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13512 Discussions
Intel NUC 10i5fnh1 slow wifi download speed on 5Ghz wifi6 ax201
Matt16
Intel NUC 10i5fnh1 slow wifi download speed on 5Ghz wifi6 ax201. When using 5 Ghz band download speed drop to 2-5 Mbps. (actual 30Mbps.)   upload speed is fine (maximum network can deliver). In 2.4 Ghz ax201 can download / upload at full speed ( 30 Mbps./ 10 Mbps.  ). I have tested this only effect intel nuc the other device ipad / laptop same distance from AP can download/ upload from 2.4/5 Ghz with network full speed. Please advise .
Thanks in advance.
Alberto_Sykes
Matt16, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance, we just wanted to confirm a few details about your system:
Is this a new Intel® NUC?
The download speed, was it working fine before?
Did you make any recent hardware/software changes?
When did the issue start?
Which Windows* version are you using?
Does the problem happen at home or work environment?
Which is the BIOS version currently installed?
What is the Intel® Wireless driver version currently installed?
Albert R.
A Contingent Worker at Intel
Matt16
1. Yes, this is new NUC10i5fnb .
2. Yes ,since the lastest update driver of wifi adaptor  the download speed only working fine when using 2.4Ghz , In 5Ghz only upload speed is working fine.
3. No, the hardware is stock from intel with latest driver update ( 21.50.1.1 Date 10/6/2019  Intel® Wi-Fi      6 AX201 160MHz )
4. when using 5Ghz channel network. ( i had check no interfere from neighbor AP)
5. win10 Home 64bit Ver.2004 (os build 19041.450)
6. i use intel Nuc only in my office ( Office AP is Cisco Aironet )
7. Current bios version :0044
 8. 21.50.1.1 Date 10/6/2019  Intel® Wi-Fi      6 AX201 160MHz
Thank you
Sasawat
Alberto_Sykes
Matt16, Thank you very much for providing those details.
By any chance, do you have the option to test the Intel® NUC with a different Router or AP just to verify if the behavior is the same?
You mentioned that if you connect any other device to that same Router, the download speed works with no problems, correct?
What is the specific model of the Router?
Did you check with Cisco directly to confirm if there might be a firmware update for that Router?
Albert R.
Matt16
i had tested with other router problem persist. The office use cisco aironet AP but i'm not sure about exact model. by the way the other the device ipad2, HP notebook with 5 years old do work fine with download / upload speedtest.net ( other device same distance from AP ) .  i do screen recording https://youtu.be/Kd_So-R2OI0   for investigate please.
Thank you
Best regards
Sasawat
Alberto_Sykes
Matt16, Thank you very much for providing that information.
We will do further research on this matter, for us to be able to do that please provide the SSU report:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Matt16
i had attached SSU file to this post as you request. Thank you for looking into this.
Sasawat
Alberto_Sykes
Matt16, Thank you very much for sharing the SSU report.
We will do further research on this matter, as soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_Sykes
Matt16, I just received an update on this matter.
Based on the details showing in the SSU report we noticed that the Windows* version is not the latest one, please install all the Windows* updates all the way to the latest build.
Additionally, there is a newer driver available on our web site, please install Intel® Wireless driver version: 21.90.3 and once you get the chance please let us know the results:
https://downloadcenter.intel.com/download/29520/Windows-10-Wi-Fi-Drivers-for-Intel-Wireless-Adapters?product=130293
Albert R.
Matt16
Hello , hope you are well, i did update windows and driver to the lastest version  but 5Ghz seem improve download from 2Mb to 7Mb still cannot match 2.4 Ghz download speed at 20 Mb. My company admin kindly gave me info from Cisco wireless controller AP side. i had attaced to this post.
Thank you very much.
Sasawat
Alberto_Sykes
Hello Matt16, You are very welcome, hope you are doing well too, thank you very much for your response and for the pictures.
We will continue with our research on this matter, since you already updated the driver to the latest version, could you please provide the SSU report again? This is for us to have the most recent configuration details of the updates that are currently installed on your platform.
Albert R.
Matt16
Hello, good news problem fix when my company admin change AP 5 Ghz from channel 64 to  44. Nuc can download and upload at full speed  but there is no interfere in channel 64 still mysterious to me. by the way thank you so much for helping me.   I truly appreciate.   i had attched ssu file as your requested.
Sasawat
Alberto_Sykes
Hello Matt16, You are very welcome, thank you very much for letting us know those results and providing the reports.
Perfect, excellent, it is great to hear that the problem with the download speed on the 5Ghz band got fixed when the company admin change AP 5Ghz from channel 64 to 44, we are glad to know the Wireless connection is now working properly.
Any other inquiries, do not hesitate to contact us again.
Albert R.
Niko87
I have a similar problem with an Omen 15 2020 notebook purchased just a few days, very slow connection in 5GHZ how can I solve?
n_scott_pearson
Super User Retired Employee
@Niko87,
While they may seem similar, every user's issues are different. You have different hardware, different driver mix, different installation order, etc. In addition, Intel Customer Support wants to track each user's issue to completion. They can't do that if you are a rider on someone else's issue. Please open your own conversation for your issue (using the Post a Message button on the main (root) Intel Community page). Please include a full description of your issue, the model of your laptop, etc. in your post
If you want to save time, please download and run the Intel System Support Utility for Windows and have it save the report to a text file. Then, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your post, upload and attach this file to the post. Intel Customer Support (as well as volunteers like me) use this information to help in the analysis and (where necessary) replication of your issue.
Matt16
Mine fix with change 5Ghz channel on router side (change to lower band ie. CH65 to CH44) and update wi-fi  driver to latest directly from intel (not from HP or intel support utility not provide update driver). You can follow this link > intel AX200 driver
Hope this help.
Cheers
Matt
Cletheroe
Similar issue, and fix, for me on a brand new Dell Precision laptop with AX201 card...
On first setup I was getting a high ping and barely 1-2Mbps at 5Ghz, despite ethernet connection proving the line was running at ~70Mbps as it should.
I tried a driver update but that had no direct effect on its own - near ethernet speeds were gained only after setting a manual 5Ghz channel on the router.
(Indicating either an issue with the particular channel my router happened to be using or its "Smart Wireless" default setting in general; I believe there is a router of the same type in the neighbouring property so it is possible that could have caused a conflict.)
Gondwana
Recently purchased a Intel  NUC11 ,i7 16GB 1TB and ran into the same issue with really slow download speeds
This problem persisted even when I used a netgear USB wifi dongle which I’ve used on other PCs with no problems
interesting reading matt16 comments and responses
ill have a play with channels on the router and see if this has any influence
I’m running Windows10 64bit which is up to date and I’ve been to the intel site to check drivers etc
Gondwana
i have reloaded the driver, tried 2 different rotuers with different service providers, tried different channels and the wifi is consitently about ten times sower on theNUC
Gondwana
I can now get it to work on the 2.4GHz but no luck on the 5GHz
