Hello community,
I am struggling with the Fan issues while NUC 11 Pro is in the sleep mode (modern sleep mode). I tried almost everything including BIOS recovery (security JUMPER was removed prior to upgrade activity), installed newer WLAN drivers than available on the official pages and then found this official article which is related to Intel NUC 11 Performance series, but it seems that behavior is valid also for my PRO series (vPRO). Could someone confirm, if fan is also running in case of the latest Windows build 21H1 with the latest patches? Does it mean, that fan will be running in modern sleep mode and it is expected behavior?? From time to time, fan is stopped, while in the sleep mode, but it is very rare situation.
https://www.intel.com/content/www/us/en/support/articles/000059300/intel-nuc.html
In the Windows System logs I see regular events related to WLAN driver (aprox. every 30 minutes):
Source: Netwtw10
Event ID: 7025
Description: 7025 - Dump after return from D3 before cmd
Source: Netwtw10
Event ID: 7026
Description: 7026 - Dump after return from D3 after cmd
I am not sure, if issue is related to faulty WLAN driver or the official KBA (thermal sensor, where temp is not below the 30C degree) It is not acceptable for me to run fan 24/7 as it is very noisy especially during the night hours.
Same issue was discussed here, but customer replaced whole unit. I have no other issues with the unit and I don`t want to return the unit back as it was ordered from different country.
Thank you and let me know, if you need more details like output from powercfg -a etc.
fyi - I am not using additional card (2x USB, 1x2.5Lan), HDD 2.5 is connected here.
Please find the export from the Intel support tool.
Hello Spidder007,
I do appreciate all the information provided, I will check the issue internally and post back as soon as I have any updates for you.
Deivid A.
Running latest Win10 Pro build using official drivers/latest Bios from May 2021.
Thank you,
Marcel
30C is 86F ... so if you live on the equator with no air conditioning ... then sure, it would never get cool enough to turn off the fan!
Hi @Spidder007
This NUC Fan off temperature is very low, it is 30C by design. When the system goes to sleep, the average temperature is between 30~40C, so you won't see the Fan Off. The sleep here means Modern Standby (S0 idle).
In high latitude countries, the environment temperature is low, so it has the chance to trigger the 30C but in the low latitude countries, the environment temperature is high, so it may not have a chance to trigger 30C.
I am saying high and low latitude countries but this is just a way to refer to low or high temperatures, hard to map to latitude considering climate change.
In short, what you are describing sounds like the expected behavior based on the answer I got from the Product Team.
If you are not happy with this situation, I would recommend that you reach out to Intel Customer Support via phone and make reference to case# 05108744.
Ronny G
Thank you Ronny for your prompt answer. I have solved it by adding "PlatformAoAcOverride" reg option in Win10 which eliminates S0 modern standby mode. Intel NUC is now quiet:)
Hello Spidder007,
Thanks for the reply.
I am glad to read that you were able to fix the issue, if you need further assistance do not hesitate to get in contact with us or you can create a new thread.
I will proceed to close this thread since you solved the issue.
Deivid A.
