Intel® NUCs
12309 Discussions
Intel NUC 11 with vPro does not recognize 2.5" SATA ssd
awoodendoll
I bought my NUC and assembled it with the parts. I use 2 SSDs which are M.2 NVMe and the SATA 2.5" drive. M.2 works totally fine but NUC BIOS does not recognize the 2.5" SSDs (WD wds500g2b0a). Also, I found some sharp folded lines on the SATA flex cable.
I wonder if the folded cable is the reason why my SSD is not recognized or is that becasue my SSD is bad out of the box? Can the community give me some advices?
I will add some of the folded lines in the flex cable
LeonWaksman
I would also check if the 2.5" SSD is inserted up to the end, making good contact with the Drive Bay connector. This video showing how to build similar NUC may help you (you may start to watch at 11:10) How To Build An Intel Gen 11 NUC
Leon
LeonWaksman
Hi @awoodendoll
The fold in the flex cable doesn't look like a problem. On the images attached to your post, I can't see how the flex cable is seating in its connector (see the red circle in the attached image). Can you check this connection? Can you attach an image showing it?
Leon
awoodendoll
Hi @LeonWaksman
Thank you for the reply
These are the images of the connector. I try to push it down and think that it is already tightly connected. The images may be hard to see because there is another flex connector above it (I cannot pull it out).
IMG-7707 - Copy.jpgLower left of the pictureLower left of the picture
LeonWaksman
Hi @awoodendoll
Tank you to provide the images. I can see that the flat cable is seating well in the connector. Try check how does it works with an other 2.5" SSD or HDD. You may borrow one from laptop? Could be that there is a compatibility problem or the NUC has a hardware failure.
Leon
LeonWaksman
Leon
awoodendoll
It finally works but I am not sure why. (It probably the connections?)
I have done the re-installation of the ssd many times and it doesn't work at all. And I did set the BIOS to default settings (F9 optimized options). After that, not immediately but I try few more times and it just work...
I did restart many times and SATA ssd still read. So, hopefully the good condition persists. Now I can proceed to the OS installation.
Thanks a lot for the help! I will mark the thread as solved.
