I’ve an intel NUC NUCi55MYHE who is continuing blinking on boot. There is the airflow and the fan go but I doesn’t want to start. Some solutions?
Let us get the model number correct first so we know what we are dealing with. You mean NUC5i5MYHE, correct?
https://ark.intel.com/content/www/us/en/ark/products/84861/intel-nuc-kit-nuc5i5myhe.html
Doc
yes, correct NUC5i5MYHE
Power on holding the power button down for 3 seconds. This should result in display of Power Button Menu. Use F2 to get to BIOS Setup (Visual BIOS) and clean up config. Can also try clearing CMOS, first from menu and then by unplugging CR2032 battery if necessary.
Hope this helps,
Hi @NicoInve ,
If reset Bios will not help I suggest the following:
- Remove and reinstall again the SO DIMM.
- If you have two memory modules, power ON your NUC with one memory module only at time.
Leon
