Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13488 Discussions
Intel NUC 8i7BEK Running of a 12-12.7 supply?
CWilc1
I am building a small robot that will be controlled with this. It would make life so much easier. If I could power everything with 12v. It says it has a 19v input but I read here that 12-24v is supported? Can anyone confirm this for the latest model? (That thread is quite old now)
LeonWaksman
  1. I can confirm that according to your NUC specification, it should work when supplied from 12VDC Power Supply. See para. 2.2.4.6 in Technical Product Specification https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i3BE_NUC8i5BE_NUC8i7BE_TechProdSpec.pdf
  2. However 12VDC is very marginal (in my opinion). How the NUC will work if under load condition, the supplied voltage will drop to 11.5VDC or even less?
  3. I suggest to you to include in you design DC to DC converter. One like this one (this is an example only and you may find many others): https://www.amazon.com/AweKing-Waterproof-Converter-Regulator-Transformer/dp/B06X3SN6QV/ref=sr_1_3?crid=RVHZ8O6CNG56&keywords=12v%2Bdc%2Bto%2B19v%2Bdc%2Bconverter&qid=1565377643&s=electronics&sprefix=12vdc%2Bto%2B19vdc%2Celectronics%2C267&sr=1-3&th=1
Leon
LeonWaksman
Leon
