- I can confirm that according to your NUC specification, it should work when supplied from 12VDC Power Supply. See para. 2.2.4.6 in Technical Product Specification https://www.intel.com/content/dam/support/us/en/documents/mini-pcs/nuc-kits/NUC8i3BE_NUC8i5BE_NUC8i7...
- However 12VDC is very marginal (in my opinion). How the NUC will work if under load condition, the supplied voltage will drop to 11.5VDC or even less?
- I suggest to you to include in you design DC to DC converter. One like this one (this is an example only and you may find many others): https://www.amazon.com/AweKing-Waterproof-Converter-Regulator-Transformer/dp/B06X3SN6QV/ref=sr_1_3?c...
Leon
Leon
