Intel® NUCs
Assistance in Intel® NUC products
13320 Discussions
Intel NUC 9 Extreme kit Power cord
Niranjan7
I am using the Intel NUC 9 Extreme Kit in a movable robot.  The NUC came with this power cord
As you can see the plug is rated for 250V/16A, while the other side of the cord is rated for 250V/10A. This means the bottle neck for this cord is 250V/10A. So can I use a 250V/10A power cord instead of the default cord that came with NUC? This is because I am powering the NUC via an inverter, on the robot. The 250V/16A plug is too big for my inverter socket.
Also, I found out that the internal power supply of Intel NUC 9 extreme kit is rated at 500W (source ). So ideally a 250V/6A power cable should be more than capable of reliably delivering power to the NUC. Is it advisable to power the NUC from 250V/6A rated power cord? (This is because I do happen to have a 250V/6A power cord whose plug is compatible with the inverter that I have).
AndrewG_Intel
Hello @Niranjan7
The Intel NUC 9 Extreme/Pro Kit Series (Products formerly Ghost Canyon) comes with an internal power supply FSP500-30AS 80+Platinum with a total output of 500W as per the Technical Product Specifications, section 2.18 Internal Power Supply, page 32-33.
In order to review your inquiries further and provide you with the most accurate information, could you please confirm the exact model of the Intel® NUC?
Note: For technical product information and specifications, we recommend our customers reviewing Intel's official resources. For instance, using Product Specification Site (ARK) or the Technical Product Specifications for Intel® NUC Products.
Andrew G.
Niranjan7
Dear AndrewG_Intel,
Thank you for the quick reply.
The model number of my NUC is " NUC9i7QNX ".
Thank you.
AndrewG_Intel
Hello Niranjan7
Thank you for your response and for confirming the model of the Intel® NUC. Please allow us to review this further and we will be posting back as soon as more details are available.
Andrew G.
Niranjan7
Looking forward to hearing from you soon.
AndrewG_Intel
Hello Niranjan7
Thank you for your patience in this matter.
After checking further your inquiry if "it is advisable to power the Intel® NUC 9 Extreme Kit - NUC9i7QNX from 250V/10A and 250V/6A rated power cords", the answer is yes. We can confirm this by referring to the information in the Technical Product Specifications, section 2.18 Internal Power Supply. Please kindly review the image below:
Internal Power SupplyInternal Power Supply
We hope this helps. If you have additional inquiries, please don't hesitate to contact us back.
Andrew G.
Niranjan7
AndrewG_Intel
Hello Niranjan7
Sure, you are very welcome, and thank you for your response.
If you have additional inquiries, please don't hesitate to contact us back. Or please kindly let us know if we can consider this thread solved.
Andrew G.
AndrewG_Intel
Hello Niranjan7
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored. It has been a pleasure to assist you.
Andrew G.
