Community
cancel
Showing results for
Search instead for
Did you mean:
canto3
Intel NUC BIOS Update via command line
Hi guys, i'm tring to install BIOS update for Intel NUC products via RMM. I can download and run the EXE file, but i have to manually click "Continue" to run the update. I can't find any switches like /s for silent install like some Dell or HP model.
Can you give me a way to do this please? I monitoring more than 500 PCs and i can't install the updates one by one. Thanks.
Community Manager
Hello, c.antoniazza.
Thank you very much for contacting the Intel® Communities Team.
I understand you would like to update the BIOS of the Intel® NUCs you are monitoring via RMM. Allow me to help you regarding this issue you are facing.
In this case, unfortunately, we do not have this feature for the firmware update of our NUCs. The update needs to be manually performed. Please accept my apologies for any inconvenience this may cause.
Antony S.
n_scott_pearson
Super User Retired Employee
Flags use dashes, not slashes, I believe. Try "-s".
canto3
Thank you Scott. It worked great!
