Hi All
do i understand correctly that the wiring between the serial port header (H) and the DB9 connector is straight. like the diagram below.
serial port header (H) - DB9 connector
1 ---------------------- 1
2 ---------------------- 2
3 ---------------------- 3
4 ---------------------- 4
5 ---------------------- 5
6 ---------------------- 6
7 ---------------------- 7
8 ---------------------- 8
9 ---------------------- 9
Are the Serialport inputs tolerant to +/-12v rs232 signal levels
The layout for a standard 9-pin serial port connector is as follows:
Per the TPS for the TN NUCs,
As you can see, it is definitely a straight-through connection from header to connector.
AFAIK, this is a TTL-level (+/-5V) serial port implementation, not a full RS232c (+/-12V) implementation. I base this premise on the fact that all previous implementations in the NUC series were TTL-level implementations. Unfortunately, AFAICS, the TPS does not properly detail the port's implementation. I have send an email to the design team for clarification. I will respond here once I have a response.
So I was correct; they described its requirements as "RS232 complaint, 5V drivers, +/-25V tolerant, support for 115.2Kb/s".
Hi Scott,
Thanks for the quick answer.
So serial outputs are at 5v and inputs will tollerate/survive +/-12v
With kind regards
Jos
Yes. The question becomes whether the other end will be tolerant of only receiving 5V. I have had mixed results myself when using these to try to communicate with older (ok, ancient) hardware.
yes thats also my concern, i asked for infomation about my RS232 device (Vantage pro weather station)
Hello JosEil,
We would like to know if you need any further assistance, based on the information given.
Steven G.
Hi Stephen,
I got all the info i needed thanks
Jos
Many thanks for your response.
Since the thread is now solved, we will proceed to close it.
Steven G.
