Intel® NUCs
Assistance in Intel® NUC products
12946 Discussions
Intel NUC BNUC11TNHi30000
zyx360
The Intel LM225-LM network card in my NUC11 is having issues.
When i power on my NUC and leave it running the wired network connection drops after about one day.
This demonstrates in Windows that the NIC adapter is unable to ping any local (ex. the gateway) ip address.
I am using a static ip address on the NIC, but the behaviour is the same with DHCP.
When i restart the OS the NIC is still unable to connect to the network after a restart.
I have to physically power off (remove the power barrel plug from the NUC) to be able to connect to the network again.
This gives me another day i can work, after which i have to do the same power-off/on steps.
I have read that the LM225-LM has a lot of issues, could it be i have a faulty unit?
Other steps i have takes;
- Reinstall the OS
- Upgrade win10 to win11
- Reinstall the NIC driver using driver assistant
- Temporarily installed different computer on same switchport, never stops working.
- Swapped switch, problem remains
What steps should i take to diagnose further?
Z
DeividA_Intel
Hello zyx360,
Thank you for posting on the Intel® communities. I understand you are having issues with your NUC.
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Have you noticed any physical damage inside the NUC or the RJ45 port (Ethernet port)?
4. Is the issue present when you connect the unit via Wi-Fi and Ethernet cable?
5. What is the brand and model name of your router/modem?
Deivid A.
zyx360
Hi Deivid ,
Thanks for the quick reply!
1. Attached.
2. Yes, it's the original onboard 2.5Gbp adapter of the nuc11
3. No damage detectable, pins look normal
4. Yes, wired drops but wifi continues to operate normally
5. KPN experia v10
Just fyi, I have another older nuc (nuc7i5bnh) and when i connect that to the same switchport it stays connected. So for me personally that rules out the network/router.
Peter
DeividA_Intel
Hello zyx360,
Based on your issue, I would like you to try the following:
1. Perform a BIOS Recovery:
2. Update the Intel® Ethernet (LAN) Network:
3. Follow the instruction from the following article:
Please let me know if the issue persists.
Deivid A.
DeividA_Intel
Hello zyx360,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
zyx360
Hi Deivid,
Sorry for not contacting earlier.
After performing those suggested steps the issues persisted.
I've created a support request and they are handling a replacement process.
I think we are good to close this one.
Thanks for your help.
Kind regards,
DeividA_Intel
Hello zyx360,
I am sorry to know that the issue persists. Thanks for letting me know that an agent is helping you with a replacement.
I will proceed to close this thread as you mentioned.
Deivid A.
