Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Intel NUC DN2820FYKH stuck at EFI screen
Yesterday my device restarted own suddenly and after boot I saw an error message first time:
The top of screen says "EFI Shell version 2.31 - Current running mode 1.1.2" followed below by "Device mapping table" "mapping"
Finally, the last line says "Press ESC in 1 seconds to skip startup.nsh, or any other key to continue". Nothing happens when I try pressing ESC or any other key though, and I can give commands by typing where "Shell>" is (it's below the "last" line). For example, if I type exit and press enter, I will enter BIOS.
I opened thge case and remove HDD and tried it but still no success. I removed and plugged RAM and I plugged out every cable and wait more than 30 minutes but I can't pass this error.
In this case what would you suggest to me?
I have Kingston SSD V300 60Gb and Win 8.1
Highlighted
New Contributor II
Re: Intel NUC DN2820FYKH stuck at EFI screen
(re)install the latest bios through the F7 method.
