Intel® NUCs
12341 Discussions
Intel NUC Ghost Canyon i9 power supply noise
Nader
I noticed that the power supply on my Ghost Canyon i9 produces some kind of a screeching noise. It seems that it is coming from the fan but I can't be sure. I appreciate if someone with the same NUC can chime on this.
AndrewG_Intel
Hello @Nader
We found that you have an internal open case describing the same issue and the same hardware environment as the one in this thread. Since Intel® Customer Support is already assisting you through the internal case, to avoid duplication of effort we will close this thread now and the support will continue through the internal case.
If you need any additional information, please submit a new question as this thread will no longer being monitored. Thank you for your understanding.
Andrew G.
Zano
I recently purchased a NUC Ghost Canyon and am experiencing the same issue as described in the post.  Has there been any resolution to fixing this ?
